Chevy TPI fuel injection
I have a chevy ZZ4 (350 cu)in my streetrod. It has a tuned port that fits a 85 to 91 camareo. It seems that when I shut the car off it looses fuel pressure. I have to turn the key on three or four times( to get the fuel pump to prime the system).
Anyone got any idea about a bled down valve or something that will keep the pressure up.
Thanks
Thanks
RE: Chevy TPI fuel injection
Thanks for the info. Do you know if there is any bleed down (I am not sure that is the right term) valve either the feed or return line that would keep pressure on the system. When I took the return line off there was no pressure.
Rich
Rich
Unfortunately I don't know your configuration ... the suggestion of the regulator came to mind from someone else who had a very similar situation.
They have a completely different make of automobile but the scenario was very similar.
After driving the vehicle there would be restart issues from no fuel pressure condition. The problem discovered was after shut down the pressure would fall rapidly ( measured at the fuel rail in this case) which was determined to be the regulator. In their case there is check valve associated with the regulator system that was allowing the pressure to bleed down the return line. Their system is located in the fuel tank by the pump.
Hopefully this gives you some insight.
laoutlaw
February 28th, 2011 8:56 AM
IROCZ5.7LITER
Camaro
February 10th, 2010 7:24 PM
