Project Car - Fuel Problem
Hi Everyone,
I purchased a '96 Monte Carlo Z34 with a few problems. First off, the timing belt was broken and it was partially taken apart. Since that time, I figured I would tear it down a little further and regrind the heads and replace all the upper gaskets and seals. So here is the problem. I have put it back together and I'm not quite sure if I have the vacuum hoses are connected correctly. When I try to start the car it fires every once in a while. The car runs if I use starter fluid or put gas in the cylinder. I think the problem lies in the fuel distribustion or a vacuum hose is not connect correct. I am hoping someone would have an idea of what's wrong. Does anyone have a picture or discription of where all the vacuum lines go?
Thanks in advance
Thanks in advance
glamisfanatic
May 1st, 2009 2:49 PM
OH6 G35
July 12th, 2007 1:19 PM
