Platform: J-body
2000 Cavalier will not start (not battery or alternator)
Old June 15th, 2010, 8:12 AM
Xerklite's Avatar
Default 2000 Cavalier will not start (not battery or alternator)
2000 Cavalier 2dr, automatic. The instrument cluster, radio and A/C blower have no power. The headlights, 4 way flashers, horn and, accessory all have power. The car will not turn over or make any noise at all. All fuses are good under the hood and are all hot. All fuses in the car are good. This has not happened before this is a first time problem for this vehicle.
Old June 20th, 2010, 12:48 PM
therewolf's Avatar
Hi Xerklite,
Welcome to the Chevy Forums.
Your battery cables are 10 years old now.(don't forget your engine-to-firewall ground strap)
What are they lookin' like? Once battery cables start to corrode under the insulation, your battery's power heats up the cable's corrosion instead of turning your starter. They don't cost much, and you can DIY.
Old April 26th, 2013, 8:14 PM
ladibuttafly's Avatar
2 dr automatic 2000 cavalier. The lights, radio, dashboard work as well but when turn the key it won't start. I need help...someone please tell me what it is. I'm a mother of two this is my means of transportation. I got a tune on my car and it started just fine but when I get in my car to run errands it wouldn't start at all.
Old April 26th, 2013, 8:33 PM
kevinkpk's Avatar
Does it crank?
Old April 27th, 2013, 7:54 AM
Originally Posted by kevinkpk
Does it crank?
No it doesn't crank at all
Old April 27th, 2013, 9:14 AM
kevinkpk's Avatar
Has it ever acted like the starter was dragging? It could be the starter solenoid, however I would think it would gradually get weak, then not crank at all. Have you tried jump starting it? Check the battery cable from the starter, I believe there is a fuseable link in it. That could be your problem.
GDATL
July 23rd, 2022 4:29 PM
d rake
June 17th, 2014 2:21 PM
jlockler
Silverado & Fullsize Pick-ups
July 8th, 2013 5:30 PM
baskervi
May 20th, 2011 10:30 AM
Igotasilveradonstuff
December 8th, 2010 12:55 PM
Quick Reply: 2000 Cavalier will not start (not battery or alternator)
