Platform: J-body
99 cavalier torn wiring harness
Old September 25th, 2013, 9:17 PM
thomas87's Avatar
Default 99 cavalier torn wiring harness
So last winter tow truck driver hooks up cable to the car (wiring harness with it) pulls cable goes through the bumper and tears about 15 wires in two. Car dies immediately. With the key in run position nothing was working i.e. lights, wipers, instm. panel, etc. So I rewired it and now everything is working, the car cranks fine but will not turn over. There are several of the same colored wire in there, for example 4 green w/ white stripe so it is possible that some of the wires are not connected to the correct end. The theft system light is also on and will not turn off not even to reset the passlock. Alt. is good, starter is good, ignition switch is good, battery is good. Its not getting a spark either. Any ideas where to start? How do I find out which wires go to what? Can I replace the entire harness?
Old September 25th, 2013, 9:37 PM
Welcome to the forum...
You can replace the harness and that would probably be easier then trying to fix it and have it hold up over time..
might check the ends of the harness for part numbers or other identifiers...
just a quick Googling of 99 cavailer engine harness turned up this link -> New Genuine GM Engine Wiring Harness Cavalier Sunfire | eBay
Old September 25th, 2013, 10:24 PM
95LamboSpec's Avatar
I would look at any local pick n pull auto parts or junk hard I your area. Fishing the wiring and replacing the harness will save a boat load of time vs trying to repair the wiring. Or you could turn to the tow company to fix it.
Old September 26th, 2013, 12:35 AM
thomas87's Avatar
Thank you for responding. The harness in this link is very small. The amount of wires hanging from the undercarriage is a bundle of 60-70 wires, its insane. Is this not the wiring harness? Is there even something to replace this or is it several different components in one bundle?
Old September 26th, 2013, 12:08 PM
If it is the wires that run to the pas side inner fender well then they probably are what feeds the ECM hooking up wrong wires could result in a nasty mess.
Old October 19th, 2013, 10:30 PM
Kaosminis's Avatar
Check J-body.org you may find many harnesses for sale on this web site. I may even have one laying around. I can check for you if have not gotten this problem fixed yet.
MMann
April 9th, 2009 10:07 PM
emamatt
Silverado & Fullsize Pick-ups
November 17th, 2008 10:02 PM
ruffrider285
April 30th, 2007 1:25 AM
j28s
November 6th, 2006 12:19 AM
Quick Reply: 99 cavalier torn wiring harness
