Platform: J-body
Oil all over the place, serpentine belt side
Old July 22nd, 2012, 2:52 PM
Brendan Baker's Avatar
Default Oil all over the place, serpentine belt side
I wanted to throw this forum out there for anyone who is having this issue with their cavalier. When you open the hood you find oil splattered on the hood possibly, its more than likely on your alternator, and pretty much everywhere on the side with the serpentine belt.
Oil loss will be very minimal but will look as if you lost a lot.
You will need a harmonic balancer puller kit, timing chain cover seal, and tools of course. Air tools are recommended but not needed.
Everything will run you about $30, if you return the balancer puller kit you will get your $20 back making the entire repair worth $10!
Here is a video on youtube which can be applied to pretty much any cavalier. Its not as easy and doesn't take 5 minutes, so put some time back in your day to make this repair.
I hope this helps anyone that has had this problem. If you let it go like I did, the serpentine belt will become saturated with oil over time, it'll squeak, and be pretty much impossible to put back on because it will try to twist. So add another $25 or so if you let this problem go too long.
Old July 22nd, 2012, 2:54 PM
Senior Site Administrator
nj85z28's Avatar
Nice post. I am going to make it a sticky
thisnthat
November 20th, 2012 11:36 AM
tastywaves
Silverado & Fullsize Pick-ups
25
October 25th, 2007 1:22 PM
stromack
December 28th, 2006 1:31 PM
kennyh
October 31st, 2006 12:01 AM
gilbertnewcomb
October 25th, 2006 6:14 PM
Quick Reply: Oil all over the place, serpentine belt side
