Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
GM 383 Stroker
Old February 3rd, 2007, 1:06 AM
weltzm1's Avatar
Default GM 383 Stroker
I am building a 383 stroker and a friend of mine wants to buy it. He has a 1981 Monte Carlo that currently has a 6-cylinder and an auto transmission. I know we can get the engine to fit but will the engine bolt right up to the transmission or will something have to be changed? Any help is appreciated. Thank you...
Old February 14th, 2007, 1:27 AM
Mezzed's Avatar
Default RE: GM 383 Stroker
ORIGINAL: weltzm1
Depending on what you've got on that 383 You might have to switch transmissions, the 383 will make too much power for that stock tranny, don't forget your going from a 6cylinder that makes probably 120rwhp to a 383 that will easily make over 210rwhp. The stock tranny "may" work for awhile "if" you can get it to bolt up, but there is no garuntee "if" it bolts up that it will even make it around the block if your friend has a "lead foot".
Old February 14th, 2007, 2:31 AM
shnormo's Avatar
Not to mention rear axle and springs.
xx76scorpsxx
Silverado & Fullsize Pick-ups
January 27th, 2016 9:53 PM
vhrocker
Corvette
13
September 28th, 2012 5:08 AM
srv748wg
May 21st, 2007 7:46 PM
srv748wg
April 23rd, 2007 1:31 AM
Quick Reply: GM 383 Stroker
