Equinox This SUV offers a smaller, sportier stance than the Trailblazer, all without compromising the SUV abilities.
Chevrolet Equinox
Platform: Theta
Daytime running lights
Old October 12th, 2010, 4:45 PM
  #11
pvb2's Avatar
Do you know the part number for the Daytime Running Lights replacement bulb? I have had no luck finding them, its not even listed in my owners manual.
Thanks,.
Old September 2nd, 2011, 10:38 PM
  #12
rongmc_2000's Avatar
anyone have part number for DRL resister on 2006 equinox?
Old September 3rd, 2011, 11:00 PM
  #13
ruley73's Avatar
The DRL resistor is GM p/n 25815013. It will probably run you about $70 or so from your local stealership. There are no aftermarket alternatives available.
Old September 25th, 2011, 12:39 PM
  #14
markeydoo's Avatar
We have a 2010 and we are looking for the DRL resistor so we can by pass it. I have looked under the left fender as the earlier models had with no luck finding it. Has anyone with 2010 been able to locate it and if so could you post pictures and a description of where it is located?
Thanks
Old September 26th, 2011, 5:27 PM
  #15
ruley73's Avatar
Thanks
The 2010 Equinox probably doesn't have the said DRL resistor. Only the 2005-2006 Equinox had it. Why would you want to bypass it? I presume to install HID headlights.
Old September 27th, 2011, 2:50 PM
  #16
markeydoo's Avatar
Yes. We are installing HID head lights and the voltage that we are getting out from the DLR is less that 12VDC. This makes the relay just chatter. Once the regular headlights come on I get 12VDC+ and the relay works fine.
LTZ_HOE
September 7th, 2021 4:19 PM
RitualJman
Silverado & Fullsize Pick-ups
14
May 9th, 2017 2:02 PM
irishflies
January 9th, 2007 10:56 AM
stingray502
October 25th, 2006 12:31 PM
Quick Reply: Daytime running lights
