Equinox keyless entry and remote start problems!Help
My keyless entry and remote start worked fine. i took the car to get an oil change and car wash. immediatly after that the remote start and keyles entry stopped working. I changed the battery and resynchronised and nothing. I found that as soon as i unlocked the car with the key and pulled the door open that it then worked fine until about twenty or so seconds after the car is shut off it stops working again. you can lock and unlock the car all day as long as a door is open or running or for about twenty five seconds after you turn off car and shut doors . then it just stops working until you open car with key again. So weird and one time it worked fine but it was raining out. has anyone had this problem and or know what to do to fix it?
So, jamie317, did you get an answer to your problem with the remote to your 2010 Equinox. I am haveing the same type problem with my 2007, and would love some answers.
I have a 2007 Equinox and my keyless entry stopped working. I took it into our dealer and they informed me that it was a recall and they reprogrammed it for free. Works like a charm no problems. This happened 08/2010.
Solved keyless entry problem with fobs for 2016 Equinox
Reply: Found spraying wd 40 in the ignition switch. Solved my problem. There is a little flap that sticks in the switch telling the bcu that the keys are still in the switch.
Rick1234 (March 3rd, 2022)
kanikedude03
Cobalt
November 11th, 2010 8:56 PM
joeysmerkz14
October 10th, 2009 2:46 PM
twizzle12
July 7th, 2009 1:33 PM
brjray
Silverado & Fullsize Pick-ups
November 6th, 2008 6:18 AM
