1996 5.o running issues
#14
I' m almost out of ideas here. Something must be heating up and causing a fault. But what would kill spark and fuel. Most of the safety switches like the neutral start kill crank, but not the ignition, unless I have that wrong.
Maybe someone else can chime in here.
#15
looks like its back to square one one, going to recheck everything out again and also replace the camshaft sensor and the ignition switch once they come in. i might have made a mistake on the spark, tried to read it at the coil instead of the plugs this time.
#16
Hey finaly got it going, just to let you know what it was' the main computer was corroded real bad on the inside, could not see the knock modual when removing from old unit to put in new THANKS FOR YOUR HELP
AirMan
Silverado & Fullsize Pick-ups
11
November 15th, 2019 9:08 AM
xitjustice
May 20th, 2013 7:01 PM
skydiverus
December 7th, 2010 4:45 PM
