2002 chevy express 2500 cargo
Old July 29th, 2011, 8:27 PM
campusman1957's Avatar
Default 2002 chevy express 2500 cargo
can any one tell me about how much weight i can put in the express i just bought i clean carpet and im installing a new machine in it and other things i just wanna know about how much i can put in it whith out killing it thanksssssssssss
Old July 29th, 2011, 11:14 PM
lc6888's Avatar
The 2500s came in 2 versions, the simpliest way is to look in the drivers door jamb where there is a label that will tell you your GVWR (gross vehicle weight rating, which means the maximum weight with all cargo and passengers) and the curb weight of the vehicle (base weight of the vehicle). GVWR minus curb weight is the max. weight you can put onto your vehicle. Another way to tell if you have the heavy duty 2500 or the light duty 2500 is to look at the wheels, if it has 8 lugs its heavy duty which I believe is 8600 lbs. GVWR and if it has 6 lugs it is the lighter duty 2500 with a 7300 lbs. GVWR. Also the HD model uses the 4L80E (larger trans.) transmission and the light duty model uses the 4L60E. Hope this helps.
hksnlper
13
October 19th, 2021 4:53 AM
dkn1997
December 5th, 2014 10:29 AM
cclifford
November 5th, 2010 10:42 AM
Vox
December 22nd, 2008 7:47 PM
chevyuser
November 11th, 2006 1:52 AM
Quick Reply: 2002 chevy express 2500 cargo
