AC Pressure Cycling Switch Question
Old Jan 21, 2013 | 7:26 PM
banner1124's Avatar
Default AC Pressure Cycling Switch Question
2003 Express AWD 5.3L here. I have a quick question about the AC system. I need to replace the low pressure cycling switch that's located on the Accumulator. I need to know if I have to have the system discharged in order to replace that switch, or can I just pop the old one off and put the new one on without discharging the system?
Old Jan 24, 2013 | 4:18 PM
tymr287's Avatar
You don't have to discharge it. Just change it out.
Old Jan 24, 2013 | 4:25 PM
kevinkpk's Avatar
Err ah, do that it will discharge.....
Old Jan 25, 2013 | 7:00 AM
tymr287's Avatar
Kevin, check your info. There is a Schrader valve under the pressure switches that seals off the system if removed. And nowhere in GM Globalconnect does it say to discharge before changing.
Old Jan 26, 2013 | 12:34 AM
MDTAHOE's Avatar
Professional Mechanic
Just change it. All pressure switches have Schrader valves as stated above.
Old Jan 28, 2013 | 9:20 PM
banner1124's Avatar
Thanks for your input everyone. To the folks who said that there was a Schrader valve behind the switch you were exactly right. Changing the switch out was as easy as removing the old one and putting in the new one. Thanks again!
loced27
Apr 17, 2013 1:50 AM
dspud2006
Feb 18, 2011 10:47 PM
heyhi
Jul 24, 2010 8:09 AM
Deteoni
Mar 28, 2009 2:01 PM
dark_waters
May 17, 2007 11:51 AM
