Call me as sharp as a bowling ball, but I can't figure how to remove the wiper blade.
Old Aug 5, 2012 | 2:11 PM
wsalopek's Avatar
Default Call me as sharp as a bowling ball, but I can't figure how to remove the wiper blade.
Hi guys,
I have a 1994 G20...replacing the wiper blades...can't figure out how to release the old blade off the driver side arm (duh). See pic:
https://www.dropbox.com/s/8rmmmyh3pi...2012.46.13.jpg
Thanks...
Old Aug 5, 2012 | 2:32 PM
kevinkpk's Avatar
Not seen one like that, someones jacked it up. Pull the locking ring (top of the pin) with a small screwdriver, pop it off, then remove the wiper arm.
Old Aug 5, 2012 | 4:11 PM
wsalopek's Avatar
I think the "locking ring" is welded to the wiper blade? Doesn't look like I can pop it off...but lemme give it a try...thanks...
Old Aug 5, 2012 | 5:23 PM
kevinkpk's Avatar
Take a small screwdriver with a small hammer pop the lockring off.
Old Aug 6, 2012 | 3:35 PM
wsalopek's Avatar
Well, I hacked and hacked and pounded and pried at that locking ring...didn't have any luck releasing it.
What it seems to have been the solution, is releasing the tension on those little wires poking up from the inside of the blade, you can see them in the picture facing AWAY from the windshield.
Those wires are the ends of a spring that are providing tension on the spring and are holding the blade on the pin/arm. Releasing those two wires and letting them/spring/fall into the inside of the blade, released tension on the spring, and released the blade from the pin/arm...though still, not without a stiff pull on the blade.
Now maybe after all my hacking away, what wound up releasing the blade was a circumstance OTHER than the way it was supposed to happen.
But trying to pop off that locking ring was either too difficult for me, and/or I just lucked out with those wires.
Old Aug 6, 2012 | 4:16 PM
kevinkpk's Avatar
Hit it with some wd40, rusted, let set then go after it again.
Old Aug 6, 2012 | 7:33 PM
TKM/Z71's Avatar
The new blades might have directions in the package.the ones I get usualy do
Old Aug 6, 2012 | 8:38 PM
kevinkpk's Avatar
If you have an autozone where you are, take it to them, they are supposed to be able to replace wiper blades.
Old Aug 7, 2012 | 9:26 AM
wsalopek's Avatar
I bought "Valeo" blades...and they did have directions, but not for that style of attachment. (But in the package there is a plastic part for proper attachment.)
Old Aug 7, 2012 | 9:27 AM
wsalopek's Avatar
Yep...very good idea...except I had bought the blades off Amazon. Anyway, it all worked out in the end.
Thanks for your help.
fcstech
Jul 2, 2008 8:57 PM
blueshark
HHR
Jun 28, 2008 10:41 PM
mwcdan
Mar 10, 2007 5:26 PM
mwcdan
Mar 7, 2007 12:38 AM
jlenkows
Oct 24, 2006 5:02 PM
