horn stopped working please help
Old Dec 3, 2012 | 2:46 PM
iamrandy's Avatar
Default horn stopped working please help
my horn on my 90 chevy van g10 just stopped working i can hear the switch working but no horn please help
Old Dec 3, 2012 | 4:02 PM
kevinkpk's Avatar
Have you checked the fuse? If it is blown, there is a reason it is. If it is the fuse, replace it, if it blows instantly, I'd suggest replace the fuse, unplug one of the horns. If a horn has a short, this will isolate which one.
Old Dec 3, 2012 | 4:10 PM
iamrandy's Avatar
no the fuse isn't blown
Old Dec 4, 2012 | 7:19 AM
iamrandy's Avatar
Come on really no one here can help me with the horn
Old Dec 4, 2012 | 9:27 AM
Retcher's Avatar
Well... I would recommend you checking the cables. That could be one of them has mechanical damage.
When did it stop working? What had happened before?
Old Dec 4, 2012 | 2:30 PM
kevinkpk's Avatar
If you have a voltmeter, unplug from the horn, take one lead to ground, and check for voltage, if you don't have it, back track to the fuse box.
Old Dec 4, 2012 | 5:42 PM
iamrandy's Avatar
yeah i went all through it today including changing out the relay and nothing, but my instrument lights went out too so i'm thinking that there's a bad short somewhere i was trying to take the fuse box off the body to check for shorts because that seems to be where the power is stopping on both things but i can't get it to come off or find any mounting screws if anyone knows an easy way to detach it it would be a big help thanks guys
Old Dec 4, 2012 | 7:55 PM
kevinkpk's Avatar
Not familiar with your body/model, I'd suggest look at the center of the fuse block for a screw, it may be a screw on fuse block to power block.
et41143
Apr 13, 2015 3:12 PM
Fishhook
Avalanche
Feb 25, 2014 2:21 PM
bigspur76
Aug 6, 2012 7:57 AM
isaac_22
Dec 26, 2007 9:23 PM
zulu
Mar 28, 2007 4:58 AM
