Possible Part Numbers for Velcro Retainer Clips ?
Old Feb 13, 2013 | 8:37 PM
Joeseph's Avatar
Default Possible Part Numbers for Velcro Retainer Clips ?
I have a 2009 Express with broken velcro clips that hold the interior right rear trim panel to the metal frame of the van.
I took some pics but cannot positively identify them for ordering replacements. As near as I can tell, they are GM part number 10280776.
It measures 20mm x 20mm x 10mm ( not counting the other half of the velcro part that is "bonded" to the van chassis )
Thanks in advance !
Attached Thumbnails Possible Part Numbers for Velcro Retainer Clips ?-velcro_clip_001.jpg   Possible Part Numbers for Velcro Retainer Clips ?-velcro_clip_002.jpg   Possible Part Numbers for Velcro Retainer Clips ?-velcro_clip_003.jpg
Old Feb 14, 2013 | 12:35 AM
canucklehead's Avatar
did you check with a gm dealer parts dept? They should be able find it.
Old Feb 14, 2013 | 7:37 AM
Joeseph's Avatar
Originally, I was told by the dealership that I would need to replace the entire interior panel ... about $300.
I told them that I'd already found the fasteners online for about $5 and would just go that way instead. They came back about 5 minutes later to tell me that Yes, they can order just the fasteners ... for about $10 each.
It worked out to be nearly the same as ordering online ... $4 each for the parts and 12-15 for shipping ... for a piece of velcro plastic ... 12-15 shipping ... yeesh !
Anyway, I got the parts today ... took a pic so at least somebody else doesn't have to guess.
Attached Thumbnails Possible Part Numbers for Velcro Retainer Clips ?-velcro_clip_005.jpg
Old Sep 25, 2021 | 10:31 AM
Triaged's Avatar
Thank you for posting this. Does anyone have the part number for the other side that clips into the sheet metal?
Old Dec 1, 2021 | 4:41 PM
radiowave79's Avatar
I also need to replace these on my 2016 Express 2500; both are missing. I am really trying to find the part number for the part that is in the metal column.
Old Dec 5, 2021 | 2:23 AM
William Kisselstein's Avatar
They used to use screws to hold things like that in place. For the cost to drill a few holes I probably would have done that, if the clip is on an interior metal area with no wires behind it.
Old Dec 5, 2021 | 10:27 AM
Triaged's Avatar
That will be the next thing I try. Even so I would need to find a piece of this specific Velcro to screw it down on either end leaving an open spot in the center for the trim side. I was thinking about trying glue first. I might also look into just doing away with the Velcro and using a thumb screw but not as clean looking.
Old Dec 5, 2021 | 2:19 PM
have you tried searching the online GM part distributors ?
gmpartsdirect, gmpartsstore, gpartsgiant etc...
Or as was previously suggested, talking to the dealership
Old Dec 5, 2021 | 2:21 PM
Triaged's Avatar
I tried searching everywhere online. I don't really have the time or desire to stand in a parts department.
Old Dec 5, 2021 | 2:26 PM
Why stand there? Call or email.
If you search for the part number that was posted above, I bet it will lead you to it's matching part.
