Replacing Alternator. Please Help!
Old Jan 22, 2013 | 2:21 PM
gingerpunkster89's Avatar
New User
Awaiting E-mail Confirmation
Exclamation Replacing Alternator. Please Help!
I'm the owner of a 82 Beauville (1 ton, v8). I like this vehicle a lot, but I've been having issues.
I've been having battery issues for awhile, even went out and bought a new one. I went to Advanced Auto Parts and had them check the battery and the alternator. Turn out my alternator is failing. I bought a new one so I could replace it on my own. Being a college student, I don't really have the money to have a shop do the work for me.
Problem is, I'm use to cars like Honda Accords where the engine is all laid out under the hood. This van seems to have half of the engine under neath a panel inside the vehicle.
Could someone either send me a link to a step-by-step guide to replace the alternator on this type of engine or tell me where the alternator is?
I know what I need to do, I just have no idea where to start.
Thanks much ^^
Old Jan 22, 2013 | 2:29 PM
kevinkpk's Avatar
You might try u tube. I've not done an alternator on a van, although it is the same less as you said, it sets in the cabin.
Old Jan 22, 2013 | 2:39 PM
New User
I've tried looking through youtube and not had a lot of luck. I'm finding truck videos mostly.
Old Jan 22, 2013 | 2:56 PM
kevinkpk's Avatar
It's pretty much going to be the same with removing the engine box what you have is the same only in more cramped quarters. This is just a mechanical tab A slot B deal with a belt.
Old Jan 22, 2013 | 3:02 PM
New User
Alright. I'll see if I can find something that is similar.
Old Jan 22, 2013 | 3:26 PM
kevinkpk's Avatar
Remove the battery terminals, those are under the hood. Remove the engine cover in the cab. Locate the alternator, it will be off the side of the engine driven by a belt. Disconnct the electrical connector. Disconnect the battery terminal (large wire). loosen the slip bracket bolt, that will allow you to move the alternator towards the engine to remove the belt. Remove that bolt, and the bottom hold bolt, remove alternator. Replace in reverse order. Reinstallation, will bottom bolt in, pull the alternator with belt on till it has tension, tighten both bolts. Now this is generic, with that I am NOT familiar with you vehicle, it could have a power sterring pump or air conditioner belt that has to be removed prior to removal of the alternator.
Old Jan 22, 2013 | 3:50 PM
banner1124's Avatar
I seem to remember that getting one of the connections off of the back of the alternator, and subsequently back on again, was much easier coming through the inside and behind the alternator
Old Feb 6, 2013 | 1:50 AM
canucklehead's Avatar
A Haynes repair manual is a must.....for 25 bucks.....its worth it.
TahoeChick805
Mar 31, 2010 10:04 AM
marcuskight23
Jun 27, 2009 8:11 PM
blaineo
May 4, 2008 3:36 PM
