rims and tires
suppose your new wheel has exactly the same backspacing as your old wheel...and you stick with 8" wide...then your tires are 28.9" tall...you can easily get a 30" tire under there so you could run 245/70/16 or 255/65/17
The thing to remember is that you need a Light-Truck Tire (10plys)....if you don't run a truck tire you'll be lucky to get 25000 miles on them...
I run Cooper Discoverer LT265-70-16 on American Racing Rims....I like the look and they are fairly quiet to run.
The backspacing on my 2016 was 4.75"
here is a great chart.....
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
put the stock tire on the left and play around with the right side
