2004 sierra 2500 keyless entry
i just bought a 2004 gmc sierra 2500 and the keyless entry dosent work. i put a new battery in the transmitter and still nothing. any help would be nice!!!!!!!!!!!!!!!!!!!!!!
RE: 2004 sierra 2500 keyless entry
[ol]Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to 4 transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
Operate the transmitter functions in order to verify correct system operation. [/ol]
try that hope it works for u.
pelletman
Silverado & Fullsize Pick-ups
October 27th, 2012 5:14 PM
