Brake Distro. Valve/Combination Valve
I had a line going from my secondary on my master cylinder to the distro/comb. valve rust out. It is now replaced but I don't want to bleed all my brakes when only half need it. If it was the line closer to the firewall then it should be for my front brakes correct?
Thanks
Thanks
closest to the firewall is the rear, it is easy to bleed, just crack the bleeder and let gravity do the work, start with the furthest brake line first (pass side rear)
whitesox1933
July 28th, 2012 8:13 PM
