power steering control valve removal
I merely want to change my pressure hose on my power steering.1992 - 5.7 litre engine. I can't get the flared end of the hose to turn that's attached to the pump but the larger nut, the control valve assembly turns. I was thinking of cutting the hose and spinning the valve assembly with spring out, and take it to the bench to work on the hose fitting. The control valve nut (24) is so thin I can't get any of my tools to fit and hold it while trying to remove the hose fitting. That's my prob. Am I asking for any trouble removing this and getting it back in? As long as it doesn't require any adjustments or the spring is too hard to decompress I really don't see any pitfalls......thanks for any input!
