Notices
water leak
Old July 29th, 2007, 1:16 PM
spinner074's Avatar
Default water leak
I have a water leak on my 88 celebrity, the water is coming in on passeger side by the air box or vents, could there be a valve sticking that directs water else where, I'm pretty sure the drain isn't clogged because water was coming outside the carwhen ac was working. it might be wishfall thinking, but it seems when the engine is warm it doesn't leak, thats why I was wondering about somekind of device malfunctioning, the water comes in when i pour water in the fresh air grid under the windsheild. Have you ever heard of something like this and how to fix it, the car is old but in good shape, I don't want the floor to rot out anymore than it prbly has, any advice would be appricated, Thank you
Old September 14th, 2007, 2:27 PM
spinner074's Avatar
Default RE: water leak
Can anyone help me with this??
Old September 14th, 2007, 10:12 PM
astroDZak's Avatar
The heater, a/c housing is directly under your "fresh air grid" remove the grid and wiper arm if need be and investigate why its getting into the heater assy.
If memory serves me you can remove the right side hood hinge from the body and support the hood the make access to the heater easier.
Try sealing around the edges with a silicon and test before putting back together.
Old September 15th, 2007, 11:44 AM
spinner074's Avatar
Thank you for the reply, I'll try that.
96TXhoe
December 22nd, 2015 10:45 AM
Fightn17
Silverado & Fullsize Pick-ups
10
April 8th, 2010 12:45 PM
billyboy
January 13th, 2007 9:10 PM
jimbo310
June 10th, 2005 12:13 AM
Quick Reply: water leak
