Notices
Window Crank Removal
Old February 14th, 2007, 1:18 PM
shnormo's Avatar
Default Window Crank Removal
Ok so take a paper clip, straighten it out and then at the end put a hook on the end of it. Push the door pannel back and then there is a washer type deal. Push that back too. Then take the hook you just made and then put it in sideways and turn it to hook the clip. Take a pair of pliers and yank the hook. Watch out cuz that clip flies out sometimes. Then you can pull the crank straight out. After you change the mirror, put the clip back on the crank and then push the crank onto the shaft.
Old February 14th, 2007, 10:41 PM
RiDiN SpInNaZ's Avatar
Default RE: Window Crank Removal
ight tight nukka i done did dat an it work
Thanx Nuka
justin69
February 28th, 2015 2:54 PM
eddychevy
Express & G-Series Vans
March 10th, 2012 4:57 PM
Roy Sutherland
September 17th, 2010 7:10 AM
davbell22602
Silverado & Fullsize Pick-ups
March 10th, 2010 8:36 PM
06HEMISPORT
February 11th, 2007 11:26 PM
Quick Reply: Window Crank Removal
