2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2000 impala no start
Old February 7th, 2012, 5:36 PM
dbgryche's Avatar
Question 2000 impala no start
I am working on a 2000 Chevy Impala. at first there was a ignition switch problem where the gauges would flicker when i jiggled the ignition”in the off position”. i replaced the switch and the flickering problem ended, now when the key is turned the gauges click twice and the security light comes on and cycles with the low fuel warning back and forth. there is no crank over nor do i hear the fuel pump pressure up.
Old February 7th, 2012, 5:53 PM
EinST's Avatar
Welcome to the forum. Did you replace the ignition switch, lock cylinder, or both? New GM parts?
Old February 7th, 2012, 6:09 PM
dbgryche's Avatar
just the switch so far and it came from advanced auto damn lock cylinder was 180.00 bucks looking for a cheaper one
Old February 7th, 2012, 6:28 PM
EinST's Avatar
The SECURITY light stays on with key on? I guess it wouldn't be the first time some aftermarket switch came defective out of the box. Either that or the Passlock electrical connector/harness is screwed up.
Old February 7th, 2012, 7:44 PM
dbgryche's Avatar
is there any way to test this and has anyone used the bypass system from newraider
Old February 7th, 2012, 9:57 PM
EinST's Avatar
Well, is the SECURITY light lit or flashing with key on? And, what 's "this" you want to test?
Old February 8th, 2012, 1:18 AM
dbgryche's Avatar
the security message and low fuel message alternate (same window differant message) and it would be the ignition switch i just put in
Another observation i had was when my obd2 scanner was hooked up i got a message that it could not make connection with pcm
Old February 8th, 2012, 11:18 AM
EinST's Avatar
Take out your multimeter, disconnect the electrical connectors from the ignition switch (take the whole assembly out or not, your choice), and then check for continuity between one connector-terminal (e.g., C1-A for connector C1, terminal A) to the connector-terminal in the next leg with key in each position as follows:
LOCK: None
ACC: C1-A to C2-C, C2-A to C1-E
RUN: C1-A to C2-C, C1-A to C2-B, C2-A to C1-C, C2-A to C1-E
START: C1-A to C2-B, C2-A to C1-B, C2-A to C1-E
Also, check all fuses labeled PCM or BCM in all the fuse blocks. As for OBD scanner issue, check the voltage at the CLSTR/BCM fuse in the left I/P fuse block.
Old February 9th, 2012, 4:43 AM
dbgryche's Avatar
thanks i'll check that out this morning and let you know what i find
Old February 9th, 2012, 5:44 PM
dbgryche's Avatar
OK NOW I'M TOTALLY LOST below are the results from the ignition switches with the checks from EINst and they make no since to me. All the fuses check out ok. and the voltage at the clstr/bcm fuse read 11.9
old switch 1a to 2c 2a to 1e 1a to 2b 2a to 1c 2a to 1b
lock - - - - -
acc 0.7 0.7 - - -
run 0.6 0.7 0.6 0.7 -
start - 0.7 0.6 - 0.7
new switch
lock - - 0.8
acc 0.8 - 0.8 - -
run 0.8 - 0.8 - -
start - - 0.8 - -
Quick Reply: 2000 impala no start
