2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2001 Impala, What do these DTC codes mean?
Old June 8th, 2009, 6:05 PM
jnshullihen's Avatar
Default 2001 Impala, What do these DTC codes mean?
I have a 2001 Impala with lots of issues, to put it mildly. I have 4 codes that are showing on the scanner, and also it has issues with accleration and is getting progressively louder. What specifically do these codes tell me is wrong. The scanner only gives a brief description.
P0131 02 Signal Low Bank 1 Sensor 1
P0404 EGR Feedback Signal out of Range
P0463 Fuel Level Sensor Circuit Signal High/Open
P1189 Engine Oil Pressure Switch Circuit
Old June 8th, 2009, 6:20 PM
ROTM Coordinator
Mike Sigmond's Avatar
Welcome to the forum!
Well lets see, does the noise sound like an exaust leak? are all your fuses good?
It helps if we have more info on your vehicle, motor size, model type, etc..
Old June 8th, 2009, 6:33 PM
It's a 3.4 Liter engine. It is just a 4-door Impala, no other letters suceed the Impala logo.
Old June 8th, 2009, 6:40 PM
ROTM Coordinator
Ok thanks! Now back to the noise that is getting louder, does it sound like an exaust leak?
Old June 8th, 2009, 6:46 PM
Yeah, it might be. I didn't know if any of the codes were related to that or not.
Old June 8th, 2009, 6:50 PM
ROTM Coordinator
Well an exaust leak will cause your o2 system to get all wacky and the EGR system, sounds like you have a good leak or break in the exaust system someware between the manifold and the cat. Look around and see if you can pinpoint it, look for black carbon buildup on the pipes or around the manifold, or you can try to feel for the leak with your hand, just be careful. Your oil and fuel codes might be a separate problem, unless the exaust leak burnt some wires to the sensors.
Old June 8th, 2009, 6:55 PM
That just might be it. If the exhaust manifold is leaking, and we replace it, would it possibly correct the O2 and EGR problem? What's the chance of that? Or would we most likely have to replace the O2 sensor and EGR valve. Also, can you tell from the codes which O2 sensor it is?
Old June 8th, 2009, 7:02 PM
ROTM Coordinator
Its hard to tell not actually looking at it, fix the leak and clear the codes, if they come back there is more to look into. I feel your EGR & O2 codes will clear with the manifold repair.
Old June 8th, 2009, 7:05 PM
OK. Thanks for the advice. Do you have any idea what the P0463 and P1189 are for? Are they fuses? I do need to check all the fuses.
Old June 8th, 2009, 7:06 PM
ROTM Coordinator
I would check just to make sure. The P0463 is the fuel level sensor & P1189 is the bank 2 fuel control, I believe.
and you are welcome.
Quick Reply: 2001 Impala, What do these DTC codes mean?
