2004 Impala - hard cold starts, gas smell
3.4l engine. At cold starting I have to crank about 3-4 times to start. Or I can turn key a few times on and off and it will start with one crank. If car is warm it will fire right up so has to be something with fuel system. I also smell gas outside of vehicle. I already changed fuel pressure regulator and still happening. Any suggestions? Car runs fine other than this. Thanks!
If I remember correctly, hope I don't get this backwards. When you first toggle the key on to start. the BCM command the FP relay to run for a couple of seconds to pressurize the system, then shuts off. When the engine gets running on that initial pressurization from turning the key, it is up to the oil pressure sending unit switch to turn the fuel pump relay back on to provide fuel pressure while the engine is running. That way in the event of a problem accident or fire and the engine stops, so does the oil pressure and in turn power to the fuel pump. Don't know if this is the case for a 2004 Impala as well.
sounds like the check valve in the fuel pump isn't working. this will cause the fuel system to lose its prime. All the fuel in the supply line will drain back into the tank after the car is shut off. the fuel lines will have to fill before the car will start.
You can confirm this condition by doing a fuel pressure leakdown test.
another possibility which would also cause a fuel smell is a leaking fuel pressure regulator.
that actually had a fuel line rot through
