2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Blower motor issue
Old September 4th, 2012, 11:59 AM
DWebb48661's Avatar
Default Blower motor issue
I have a 2003 Impala that the blower motor quit working. It will run occasionally but most of the time not. I have removed both the blower motor & resistor and replaced them but it still does not run on any speed. I've found that it will run when after starting the engine if I turn the key to towards the "start" position. Also, the AC control will not work properly with the switch in the run position. Again, with the switch held in the early stage of the "start" position I am able to turn on & off the AC with the button in the dash.
Any ideas???
Old September 4th, 2012, 12:54 PM
kevinkpk's Avatar
The switch is attached to a small rod that when the switch is moved to on, start the rod moves to make the switch (on the column) contact. I'd guess either contacts are dirty, or rod needs adjusted.
Old September 4th, 2012, 1:13 PM
DWebb48661's Avatar
The ignition switch is mounted in the dash not in the steering column.
Old September 4th, 2012, 1:16 PM
kevinkpk's Avatar
Sorry. Can you see the electrical connector under the dash on the switch? I'd suggest pop it off, and with some spray electrical cleaner spray them. It maybe the switch is slightly worn causing an intermittent contact.
Old September 4th, 2012, 1:25 PM
DWebb48661's Avatar
The ignition switch was replaced about 2 years ago.
Old September 4th, 2012, 1:40 PM
kevinkpk's Avatar
Old September 6th, 2012, 7:12 AM
DWebb48661's Avatar
The ignition switch was bad. I replaced it and everything works now.
skidoofan
December 8th, 2014 7:44 PM
cableguy83
July 15th, 2012 2:37 PM
Kinkade71
March 17th, 2012 3:22 PM
SterlingB
July 16th, 2011 3:22 PM
The Alpha Dawg
January 13th, 2009 7:03 PM
Quick Reply: Blower motor issue
