2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Trac off/service traction system/ABS lights
Old August 27th, 2015, 4:12 PM
Bleeneel's Avatar
Default Trac off/service traction system/ABS lights
I've had car to my mechanic 3 times with this issue and he says brakes are fine and to ignore the lights when they come on.
I've stopped by 2 other repair shops to discuss and they basically say the same thing
But I believe there's a problem in that I feel the brakes grab sometimes and car is slow to excelerate from a full stop.
Any help much appreciated!!
Old August 27th, 2015, 9:33 PM
Frank3's Avatar
What year and is this a car you've owned for a while (history) or new to you?
Old August 27th, 2015, 9:37 PM
Bleeneel's Avatar
Its a 2003 Impala I bought used in 2008. So I've had it 7 years.
Old August 28th, 2015, 10:54 PM
Frank3's Avatar
Did you get the car scanned for any codes? My 2001 Impala needed to have the wiring replaced for the wheel sensors. I got the repair kits from my dealer then cut out the old sections of the harness and then connected up the new ones to replace them. I guess all the movement of the lower control arm gradually weakens then causes the wires for the sensors to break. After replacement, my lights went out.
Old August 29th, 2015, 10:49 AM
Bleeneel's Avatar
Thank you Frank!
Old August 29th, 2015, 10:56 PM
sledge.impy's Avatar
So has your battery replacement fixed this also?
Or is this still an issue?
Old August 30th, 2015, 11:04 AM
Bleeneel's Avatar
Still an issue. I think its getting worse so I'm parking it until I decide where to take it.
Old August 31st, 2015, 7:50 PM
Do these cars go into limp mode with reduced power?
Your mechanic pulled the wheels and inspected the caliper pins for movement? Did he re-grease them?
Old August 31st, 2015, 7:51 PM
and I guess have you ever had the brakes done, if so - how many miles ago and who did it?
Old August 31st, 2015, 8:02 PM
Bleeneel's Avatar
Issued first happened I took to my mechanic. He said there was a sensor issue and he had to buy in an assembly...also put new pads on. It was doing same thing within a day and I've taken it back to him twice. He swears they took all four wheels off and checked...that brakes are fine and just ignore the lights. It is very slow to accelerate at times.
Thanks for your time.
Quick Reply: Trac off/service traction system/ABS lights
