Steering pump issue
Steering pump issue
My power steering is bad when I'm trying to park Or when the rpm's are under 1000 if I'm in park or neutral and I step on the gas and go over 1000 rpms the steering is normal like it should be... Also every time I open the reservoir like to check the fluid it let's out pressure when I take the cap off it sounds like when you open a soda can... I've been told three different things by three different mechanics..."it's the power steering pump" "it's the rack and pinion" and "it's a power steering line clogged up" I don't know where to start I don't have much money....
That's usually a symptom of a worn power steering pump and, perhaps, contamined fluid. So, I'd pick mechanic number 1, i.e., replace the pump and, what usually goes with it, flush the system.
22charlie
March 21st, 2013 9:54 AM
w002mia
Silverado & Fullsize Pick-ups
March 18th, 2013 11:42 AM
treasurehunter01
January 11th, 2009 11:33 AM
cc2001
April 20th, 2008 9:43 AM
