Chevrolet Malibu
2003 Chevy Malibu open trunk button
Old May 11th, 2009, 6:32 PM
chevydriver0000's Avatar
Default 2003 Chevy Malibu open trunk button
Does anyone know of a good way to disable the trunk-open button (located left of the steering wheel) on this car?
I'd like to make it difficult for someone breaking into my car to access my trunk contents. Also, sometimes I like to leave windows open on a hot day when I run to the store, but I don't want someone reaching in and popping the trunk open.
Is there a way to do this without destroying anything?
Old May 12th, 2009, 8:24 AM
Banned
OnDaGround's Avatar
Unplug the switch connector. Or the fuse. If you unplug the switch connector you might still be able to access the trunk using your remote instead of your key. Not sure though. Never tried.
Old May 12th, 2009, 2:43 PM
Thanks. I should have realized there was a fuse for this, but didn't. Pulled the fuse... that's good enough.
Old May 12th, 2009, 2:56 PM
Banned
OnDaGround's Avatar
No problem. Like I was saying though, with the fuse pulled you won't be able to access your trunk using the key less entry. So it may be convenient for you to pull the connector off the plug when you get more time. Then stick the switch back in the dash.
blueflirt03
April 22nd, 2010 8:10 AM
DUNTOV
November 13th, 2007 11:28 AM
asjah73
January 21st, 2007 5:46 PM
asjah73
January 18th, 2007 7:43 PM
Quick Reply: 2003 Chevy Malibu open trunk button
