Chevrolet Malibu
dealer repairs?
Old Jun 18, 2012 | 3:47 PM
josephus's Avatar
Default dealer repairs?
2007 chevy malibu. dealer said I had to replace BCM, and dealer said instrument cluster bad too.. Do you have to replace both as a pair if nothing wrong with instruments? Initial problem radio and indications on radio panel intermittent. Thanks.
Old Jun 18, 2012 | 5:14 PM
kevinkpk's Avatar
I don't believe it is the body control module. If it is a warrenty issue, let them decide, else, they'd have to prove one or the other or both.
Old Jun 19, 2012 | 3:06 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> josephus,
The only problem was with the radio? Could you describe what was occurring?
Louis
GM Customer Service
Old Jun 20, 2012 | 8:59 AM
scorpion48's Avatar
Default I may have the same problem
If what he has been having happen is every so often I start the car and the radio display is out. I turn off car and restart and it's back on. This wouldn't be a problem if GM didn't put the info center in the darn radio. If it weren't in the radio I would just change radios but I lose my tripometer, oil change due, and my MPG readings. And you know if I would buy another factory radio it would cost me an arm and a leg. I'll live with mine till I can't get it back on anymore.
jfighter
Sep 10, 2010 11:06 PM
Evan
Dec 9, 2009 8:01 PM
skirunner
Jan 27, 2009 10:24 AM
agentfox1942
Sep 27, 2006 7:27 PM
agentfox1942
Avalanche
Sep 22, 2006 4:38 PM
