Chevrolet Malibu
po455 large evap leak detected
Old September 9th, 2010, 2:49 PM
izzyrn's Avatar
Default po455 large evap leak detected
Is the evaporator vent solenoid stuck in open position and does it need to be replaced?
Old October 14th, 2010, 7:24 PM
2000Impalaspeeder's Avatar
I have the same code P0455 in my car..
Do you have difficulty starting your car when cold?
because I do I start my car up the 3rd time.
Old June 25th, 2012, 12:56 PM
Coby1's Avatar
I had that same code p0455 in my truck. so I change the purge solenoid on the engine near the fuel rail above the manifold and that took care of the code. If you are doing the work yourself you need to take the negitive cable from your battery before you do your work. Once you finish the work connect the battery back up and run the vehicle to see if the code comes back, it did not come back in my truck.
malglot
Sonic (Aveo)
14
October 9th, 2022 3:28 AM
Mike Alpha
May 31st, 2015 1:38 PM
SeanCasey
April 5th, 2010 11:20 PM
10gunman
December 26th, 2008 8:40 PM
akimber
Silverado & Fullsize Pick-ups
14
August 22nd, 2006 11:45 AM
Quick Reply: po455 large evap leak detected
