Chevrolet Malibu
po455 large evap leak detected
Old Sep 9, 2010 | 2:49 PM
izzyrn's Avatar
Default po455 large evap leak detected
Is the evaporator vent solenoid stuck in open position and does it need to be replaced?
Old Oct 14, 2010 | 7:24 PM
2000Impalaspeeder's Avatar
I have the same code P0455 in my car..
Do you have difficulty starting your car when cold?
because I do I start my car up the 3rd time.
Old Jun 25, 2012 | 12:56 PM
Coby1's Avatar
I had that same code p0455 in my truck. so I change the purge solenoid on the engine near the fuel rail above the manifold and that took care of the code. If you are doing the work yourself you need to take the negitive cable from your battery before you do your work. Once you finish the work connect the battery back up and run the vehicle to see if the code comes back, it did not come back in my truck.
malglot
Sonic (Aveo)
15
Apr 6, 2025 1:33 PM
Mike Alpha
May 31, 2015 1:38 PM
SeanCasey
Apr 5, 2010 11:20 PM
10gunman
Dec 26, 2008 8:40 PM
akimber
14
Aug 22, 2006 11:45 AM
