Platform: A-, G-, & W-body
1995 Lumina Hesitation/Stumble
Old August 18th, 2008, 8:32 AM
wilke_jb's Avatar
Default 1995 Lumina Hesitation/Stumble
I have a 1995 Lumina. It idles nice. You can rev it in neutral up to about 3500rpm then it stubles - almost like it is hitting a rev limiter - not the problem, just a symtom. When you go to drive it, when you initially step on the gas it will stumble and buck BADLY, sometimes it will 'catch' and will go like a bat out of you know where. I had the fuel pump and filter replaced, and the fuel pressure all looks good and I just did a tune up, wires and plugs. The coil packs ohm out ok, there are no codes to speak of. I have an actron CP9185 scan tool to check the codes and see live data. The tool says that I have a bad 'Quad driver 4' - but some have said that the toolwill say this in error? I am leaning toward something in the transmission, but I'm not sure. I really don't know what to do with this car and any help would be appreciated.
Old December 12th, 2008, 9:04 PM
fastback4's Avatar
Default RE: 1995 Lumina Hesitation/Stumble
I've seen a cracked coil pack and plug wire grounding out on the engine cause a stumble like this.........Tom
Old December 13th, 2008, 9:23 AM
wilke_jb's Avatar
ended up being a bad coil pack. thanks for the reply
QBert
May 5th, 2021 10:00 PM
steiblerm
June 30th, 2013 10:45 PM
83trekker
March 23rd, 2013 12:50 PM
gedbuch
Silverado & Fullsize Pick-ups
March 27th, 2012 5:54 PM
dg123
February 17th, 2008 8:22 PM
Quick Reply: 1995 Lumina Hesitation/Stumble
