HELP PLEASE! 1999 Chev Tahoe Interior Dome & Door Lights
Old Jun 9, 2013 | 3:19 AM
slimkim's Avatar
Smile HELP PLEASE! 1999 Chev Tahoe Interior Dome & Door Lights
I am new to this forum. No interior lights come on when door(s) are open. What's the problem? What do I do? How do I fix this? Thank you!
Old Jun 9, 2013 | 6:43 AM
Always look at the obvious first. Check all the fuses as they may be marked as something other than they are.
Old Jun 9, 2013 | 7:20 AM
nj85z28's Avatar
Senior Site Administrator
Thanks for joining, slimkim! Glad to have you as a part of our community
Old Jun 10, 2013 | 5:41 AM
slimkim's Avatar
Ok. Thank you. I'll try.
Old Jun 11, 2013 | 2:38 AM
slimkim's Avatar
All the fuses in the dashboard are good. I can see the pop out button thingy right above the fuse box but I don't know how to get it out.
Old Jun 17, 2013 | 11:18 PM
slimkim's Avatar
oldchevy & nj85z28==Where do I go from here?
Old Jun 18, 2013 | 10:57 AM
There is a fuse box under the hood. Also check all of those fuses.
Old Jun 20, 2013 | 2:36 AM
slimkim's Avatar
:-) Thank you will do!!
Old Jul 5, 2013 | 9:27 PM
kybasshunter09's Avatar
I'm new to the forum also, I was just browsing around and found this post. If its not the fuses make sure to check and see if the button that controls your interior lights is pushed in. It should be right under your headlight selector. Sometimes mine don't come on and I have to push it in and out serval times. Also the door and a pressure sensitive button on the side paneling right above the fuse box. Theres also another one on the opposite door in the same spot. A wire could be loose there. Hope that helps some!
Old Aug 9, 2013 | 7:04 PM
slimkim's Avatar
I did, THANK YOU! ;-) They are all ok. Now ? I will look for the door switches. I don't know where the one(s) are for the rear doors. Treasure hunt time! :-D
