S-10 & Blazer 1982-2005
350 Engine and What type of Transmission
Old January 22nd, 2007, 11:10 PM
ian_maham's Avatar
Default 350 Engine and What type of Transmission
I am currently purchasing a 350ci / 330hp '350 H.O.' engine for my 1997 regular cab S10. Right now i am stuck and do not know what type of transmission i should purchase. please give any supportive advice on the type of transmissionand where i might be able to purchase it. also any other information needed for the swap would be great. thanks
Old January 23rd, 2007, 12:51 AM
CrashNburn's Avatar
Default RE: 350 Engine and What type of Transmission
automatic or standard? for an automatic you have to decide what you want to do with the truck, then your choices are the TH350, or the 700R, or the 4L60, or the 4L60E.... depends on the year the engine and what wiring you want to do, is it a street truck, 4X4... show truck... DD.
Old January 23rd, 2007, 4:24 PM
ian_maham's Avatar
Here is the engine that i am getting... http://www.jegs.com/webapp/wcs/store...49874_-1_10763
and the truck is going to be street, it is nota 4X4. and i definently want a manual transmission. and what type of wiring do you reccomend?
Old January 23rd, 2007, 6:58 PM
CrashNburn's Avatar
if you go with a manual transmission, and a carburator, you only require 4 wires I think to make it run.. (someone correct me here cause i havnt done this type of job in a while).. you just need to tell your starter to turn (you dont even need to use a key if you dont want to). and when your engine cranks you need a signal from your engine to your coil and your coil to your distributor. i will look in one of my books to see if i can find a wireing diagram that will work for you.
Old January 24th, 2007, 2:51 AM
ian_maham's Avatar
Thanks alot, your advise is really helping me out.
badwench
October 30th, 2012 11:50 AM
vzereeys
Engine Building & Overhauling
September 25th, 2012 1:11 AM
Astroman93952000
Astro
September 12th, 2012 12:45 PM
jgray152
Silverado & Fullsize Pick-ups
July 12th, 2010 8:22 PM
enovativ
April 9th, 2007 12:20 AM
Quick Reply: 350 Engine and What type of Transmission
