S-10 & Blazer 1982-2005
all 4 turn signals & turn flasher out, but hazards working fine
Old Apr 28, 2008 | 11:15 AM
Manor_Mullet's Avatar
Default all 4 turn signals & turn flasher out, but hazards working fine
All 4 of my turn signals are out. The turn flasher on the dash does not work-- no click or flash.
However, the hazard signals and the hazard flasher works great. They use all the same bulbs, therefore it must be a turn switch failure right?
Is there a way to repair this without buying a whole switch assembly ($157, rockauto.com)?
Old Apr 28, 2008 | 1:51 PM
Default RE: all 4 turn signals & turn flasher out, but hazards working fine
The turn signal fuse was fine. There was voltage at the turn signal connectors. I replaced the turn signal flasher relay ($4), and problem solved.
Old Apr 28, 2008 | 2:13 PM
EvansBlue's Avatar
Congrats! Solved your own problem! lol. I've done that before.....
I was about to recommend changing the flasher.
Jakester
14
Jun 15, 2023 11:38 AM
ExBest182
Oct 5, 2013 4:26 PM
Lymsleia
Aug 14, 2011 10:48 PM
SILVERAD01
Jan 21, 2009 9:14 AM
dstedman
Sep 9, 2007 10:24 AM
