help 1994 chevy blazer
i have a 1994 chevy blazer that is just killing me, it didnt want to start you had to keep cranking it to get it to finally start.so i replaced the starter ,the coil,the pick up coil, the ignition module it worked for awhile then same problem again,well replaced fuel filter new plugs wire, rotor and cap same problem still, then replaced spider assembly because it was leaking, replaced every sensor because it blew a code for the erg vale, so replaced every sensor on engine, now you have to hold gas pedal down and crank it to get it running it also blows carbon out exhaust now when first started. please help at my wits end thank you
RE: help 1994 chevy blazer
CPI?
It honestly sounds like you have no idea what you are doing. You could have took all that money you just threw at it and took it to a dealership and probably got it fixed.
Are you sure you installed that spider correctly?
zachsny
November 15th, 2011 7:19 PM
