S-10 & Blazer 1982-2005
need help with 01 Blazer
Old Oct 20, 2012 | 11:39 AM
DMez's Avatar
Default need help with 01 Blazer
I have had a problem with surging when getting on the highway and got to a point where I had a hard time getting up a hill, checked fuel pressure; it was low so I changed the fuel pump and filter. started right up. took it for a ride, the surging was worse but with more power, and it seems like the tranny doesn't want to shift(just had that rebuilt 2 years ago). with the truck in Park and revving the engine I hear a loud knocking noise. put a scan tool on it and comes up P0300 . checked for vacuum leak, found none. After running I can smell burnt rubber from under the truck.
Old Oct 20, 2012 | 1:47 PM
kevinkpk's Avatar
That code is misfire, is it the only code?
Old Oct 20, 2012 | 1:51 PM
kevinkpk's Avatar
One thing you can try, take WD-40 and spary the plug wires, and coil pack plugs. If it is moisture that will cause your symptoms. Is there a chance of bad fuel?
Old Oct 20, 2012 | 7:26 PM
DMez's Avatar
that is the only code and I have tried 94 oct. for gas and dry gas.
Eddie02780
May 11, 2015 5:19 PM
stshadow
Apr 22, 2011 9:48 PM
BriansBowTie
Mar 24, 2008 11:27 PM
BlazerZr2
Feb 18, 2007 7:11 PM
crazyfishinnut
Sep 27, 2006 1:35 AM
