Rpm fluctuation at highway speeds
Old Sep 2, 2009 | 5:50 PM
  #11
bowie's Avatar
I am having the same problems with the fluctuation in shifting. I have had the oil changed and filter and it is still doing it. Are there any other ideas??
Old Sep 3, 2009 | 5:24 PM
  #12
bowie's Avatar
Is anyone out there?
Old Sep 4, 2009 | 9:16 AM
  #13
Chupp's Avatar
I originally posted this thread and since I have had the trans fluid changed and the system flushed. since then I haven't noticed the rpm fluctuation anymore but also it is a lot warmer now than when I first got the vehicle and I don't drive it that much. Another thing to mention is that the local shop I had the flush done charged I think around 150 bucks for the flush and change.
Old Sep 8, 2009 | 9:48 AM
  #14
bowie's Avatar
I will give that a try. I did change like half the fluid and it really did not do anything for the fluxuations. They are still happening.
Old Oct 26, 2019 | 12:08 PM
  #15
Klawtrax's Avatar
Exclamation Any Solution Found
I have a 2001 Chevy Blazer with very high miles but in great conditions. I am also experiencing the same problem with the tach jumping up and down while cruising at normal speeds when you have to add just a small amount of throttle. I have not taken it to a Tranny shop yet in fear of the outcome.
what I have done
tranny fluid and filter change with added Lucas treatment.
plugs, wires,cap and new distributor
throttle positioning sensor
fuel pump and filter
fuel pressure regulator (solved the long starting problem)
replaced most vacuum hoses (solved the 4x4 switching problem)
will the tranny need replaced if it is the TC disengaging?
I have noticed that this is a BIG problem from all the forums and the Youtube vids. So either people are selling their trucks, living with the problem or they have found the Solution but not posting it.
Thanks for any feed back.
Old Mar 23, 2021 | 4:49 PM
  #16
B-Dub's Avatar
Try tcc sensor or could b a bad converter im experiencing the same thing will let u know what I find out
Old Apr 14, 2021 | 10:19 PM
  #17
juggalo jay's Avatar
Any body figure it out it happens with my 5.7 vortec their 250,000 in my savannah van and just bought a jimmy with 4.3 100,000 with the Vin w and having the same problem seems to only do it at constant speed im tired of dumping money into them its like trying to chase a ghost problem.. im thinkin it's the tc only thing I haven't replaced
Old Oct 27, 2021 | 7:59 AM
  #18
Toriscar's Avatar
Default Same problem solution?
Did you figure it out?
Cbaker
Aug 5, 2022 10:01 PM
3800Impala
Jan 30, 2017 1:28 PM
lunghd
Apr 28, 2016 8:05 PM
jeckle5010
1988 - 1998 (GMT400)
Mar 22, 2016 4:14 AM
deer_assassin89
Aug 27, 2011 11:51 PM
