TrailBlazer 2002-2009
05 driver side control panel not working...
Old Jun 2, 2009 | 1:34 PM
  #11
Jackals7's Avatar
I can't remember off hand if its LS or LT. I know its 6cy, 4wd and not ext model.
Old Jun 2, 2009 | 1:58 PM
  #12
Mike Sigmond's Avatar
ROTM Coordinator
These are most likely your diagrams...
File Type: pdf
File Type: pdf
Old Jun 3, 2009 | 7:57 AM
  #13
Jackals7's Avatar
Well so far so good. I didn't notice anything too bad. I did notice a couple corrosion areas but didn't look bad to me. I sprayed it all and put it back in and it worked. Hopefully it will continue to work and wasn't just me messing with the wires and will stop working again.
Thanks for you help!!
Old Jun 3, 2009 | 9:47 AM
  #14
ROTM Coordinator
No problem, I hope it stays working too
Old Jun 19, 2009 | 6:47 AM
  #15
Jackals7's Avatar
Well the problem is back. the control panel is dead (as of right now) All other windows and locks work. Nothing is workable from the driver side panel
Old Jun 28, 2009 | 8:23 AM
  #16
Jackals7's Avatar
Does anyone know that if I replace this control panel if any programming would be needed? I think I did enough trouble shooting to find out it is the control panel that is bad. I swapped it with the passenger side. Once I did that the passenger window would not work and now the driver side does work.
Old Aug 16, 2014 | 10:13 PM
  #17
jonhamnwa's Avatar
there is a recall at least on my 2007 for the driver door master control tho parts will not be avail till October and guess what moisture incursion
1948hummer
Apr 1, 2013 7:59 PM
wsalopek
Jun 20, 2012 10:45 AM
tbehman@gmail.com
Cobalt
Apr 13, 2011 11:21 AM
mossyoakman
Apr 3, 2011 8:39 PM
jbravo8212
Nov 25, 2007 8:35 PM
