S-10 & Blazer 1982-2005
98 blazer clink noise when accelerating (need help)
Old Sep 24, 2009 | 9:16 PM
  #11
MDTAHOE's Avatar
They could not properly do the alignment with out relpacing the ball joints. What about the transfer case fluid?
Old Sep 27, 2009 | 1:10 AM
  #12
breakyadown89's Avatar
ya i know that now. i paid all that money for an alignment and now my alignment is still off, i asked the idiot at car x if it will make a difference without getting my ball joints done and he said no. there is transmission fluid now in the transfer case. can a bad axle make that noise.
thanks for the help
Old Sep 27, 2009 | 4:39 PM
  #13
the noise was my drivers side axle the inner boot was cracked and the grease was every where. Thanks
Old Oct 14, 2009 | 1:08 AM
  #14
Bill's Dad's Avatar
check the torsion bar mounts, though I would think they would have? and they usually make a clunk when body flexs/turning? midway under truck, the rear/end of each bar fits into a crossmember which mounts to frame using these torsion bar mounts(they're like a motor mount-a thick rubber adhered to the steel. The rubber comes unattached, to check, you must simply pry up or lift up w/hydrolic jack and look at mount. They cost like 35.00ea.
jhawkins
Aug 4, 2020 5:13 AM
dougd
Mar 7, 2019 7:28 AM
Sparkym300
Mar 6, 2019 9:14 PM
ericselk
Jul 8, 2009 8:37 PM
delgado
Jan 7, 2009 8:54 PM
