loud popping clink when put in drive
Old Jan 5, 2009 | 8:31 PM
delgado's Avatar
Default loud popping clink when put in drive
96 suburban makes loud popping clink from back of truck when shifted into drive,can anyone help with what could cause this?
Old Jan 5, 2009 | 8:40 PM
mean327's Avatar
Default RE: loud popping clink when put in drive
your u joint on the rear may be going bad
Old Jan 5, 2009 | 9:01 PM
delgado's Avatar
any way to tell if it's the ujoint?
Old Jan 5, 2009 | 11:16 PM
old dog's Avatar
get it up in the air see if there is any rust stain coming out ,try to rotate the shaft back and forth with your hand on the rear end yoke to see if their is any movement in the joint .
Old Jan 6, 2009 | 4:18 AM
delgado's Avatar
any way to tell if its the rearend?
Old Jan 6, 2009 | 9:09 AM
old dog's Avatar
try grabbing the drive shaft like mentioned before see how much movement there is in the rear end when you twist the shaft ,there will be some wind up on old trucks .if excessive you might need to have the lash on the carrier bearing's re set .
Old Jan 7, 2009 | 8:54 PM
delgado's Avatar
thanks guys,got it up on a rack at my buddies and we come up with bad ujoints
Diamondlace
Aug 13, 2014 8:33 PM
jkucera07
Aug 9, 2011 3:35 PM
tlaura21
Jun 2, 2011 7:35 PM
breakyadown89
Oct 14, 2009 1:08 AM
TBarwick1
Jun 5, 2007 9:26 AM
