loud popping clink when put in drive
get it up in the air see if there is any rust stain coming out ,try to rotate the shaft back and forth with your hand on the rear end yoke to see if their is any movement in the joint .
try grabbing the drive shaft like mentioned before see how much movement there is in the rear end when you twist the shaft ,there will be some wind up on old trucks .if excessive you might need to have the lash on the carrier bearing's re set .
jkucera07
Aug 9, 2011 3:35 PM
breakyadown89
Oct 14, 2009 1:08 AM
TBarwick1
Jun 5, 2007 9:26 AM
