07 Tahoe Driver Side Mirror
Old Jun 11, 2007 | 11:02 AM
  #41
ZX1100F1's Avatar
Default RE: 07 Tahoe Driver Side Mirror
Stick them on and have a dealer reflash your Tahoe's DDM and PDM.
Old Jun 21, 2007 | 8:39 PM
  #42
cruzsuburban's Avatar
I need help to replace my manual folding to power folding mirrors I have the new mirrors but I need to know if I have to get additional parts like wire harness and suitches, Thanks
Cruz
Old Jun 21, 2007 | 11:00 PM
  #43
07tahoe's Avatar
check out this thread lots of info.
https://chevroletforum.com/m_11921/mpage_1/key_/tm.htm
Old Jul 16, 2007 | 12:56 AM
  #44
gfraigun
Guest
Posts: n/a
Are these the same directions for non-powerfolding mirrors?
ORIGINAL: ZX1100F1
Here's how to replace just the glass:
Position the mirror face outward on an angle with the mirror housing.
[ol][/ol]
Remove the mirror face as follows: Position the hand in the center of the mirror face. Apply light pressure. Push upward releasing the motor retainers from the mirror back. Holding the mirror face, disconnect the electrical connectors from the back of the mirror.
[ol][/ol]
Old Jul 16, 2007 | 2:33 PM
  #45
gfraigun
Guest
Posts: n/a
Does any of this apply to the non-power folding mirrors that have the vibration problem?
ORIGINAL: ZX1100F1
If recycling the mirror does not fix the problem have your dealer take a look at Service Bulletin Document ID# 1852141 That reads:
Condition
Some customers may comment that the left outside mirror glass shakes or flutters at normal driving speeds.
Cause
• The mirror may have been accidentally pushed in manually or obstructed while folding.
• The mirror actuator screws may be loose, allowing the mirror to move.
• The metal spring may not have enough tension to hold the mirror from moving.
Correction
Follow the procedure below to correct this condition.
The power folding mirrors should be cycled three times to relearn position. Then perform a road test and check the mirror glass for stability. If stability is not fixed, proceed to step 2.
Remove the mirror glass. Refer to Mirror Face Replacement in SI.
Check the torque on the four retaining screws on the actuator.
Tighten
Tighten the screws to 1.13-1.6 N·m (10-14 lb in).
Bend the metal spring up to increase tension engagement to the mirror housing 13 mm (1/2 in).
Install the glass assembly by pressing firmly, taking care not to allow the spring finger to unseat from its intended track in the mirror housing. Road test the vehicle. If stability is not improved, replace the mirror assembly. Refer to Power Mirror Replacement in SI.
Old Jul 27, 2009 | 10:55 PM
  #46
HoleInOne's Avatar
Anything new on this?
Old Jul 30, 2009 | 8:36 AM
  #47
Willys 53's Avatar
I'm experiencing this issue with non-power folding mirrors on my '07 Suburban - driver's side only. The earlier post about vibration getting worse after the Service Dept. took their mirror apart concerns me. Any suggestions for non-power folding mirrors?
Old Oct 26, 2010 | 12:54 PM
  #48
Brandon2007Tahoe's Avatar
my driver's mirror has the auto dim feature at night - it makes everything appear blurry. is it possible to disable the auto dim feature on only the outside driver's mirror? thanks.
Old Oct 27, 2010 | 8:38 AM
  #49
Official GM Rep
I looked through the owners manual for the 2007 Tahoe and it states that the outside auto dimming mirror function is controlled by the auto dimming rear view mirror inside the vehicle. To turn it off you would have to turn the entire system off. I hope that helps you. You can find this information on page 167.
Jeff Morris, Chevrolet Customer Service
Old Oct 27, 2010 | 12:25 PM
  #50
ousig2408's Avatar
old thread! our driver side mirror vibrates very bad also. I am probably going to take it in to get our cracked dash replaced sometime soon. Is there any other info regarding the mirror or how to keep it from vibrating? I can't even look at it at night because the lights are all blurry and shake so much.
