Rear Defrost Window Tabs
Old Feb 21, 2008 | 11:57 PM
ncfr2544's Avatar
Default Rear Defrost Window Tabs
Does anyone know how the rear window defrost tabs are held onto the window on the '07 Tahoe? I was driving down the road today and something kept dangling in my rear view mirror. Come to find out...my rear window defrost post that the squiggly thing hooks onto has detached from the window. Is this something I can repair myself with a special type of sauter metal or should I let my dealer fix it?
Old Feb 22, 2008 | 8:49 AM
jlenkows's Avatar
Default RE: Rear Defrost Window Tabs
Give it to the dealer!!!!
Old Feb 22, 2008 | 10:11 AM
rs2tech's Avatar
Mine did the same thing on an '07 and the dealer said that the rear window must be replaced.
Old Feb 22, 2008 | 1:28 PM
ibcheeky's Avatar
Permatex makes a special adhesive for repairing this. You can find it at Most auto parts places.
Permatex
[IMG]local://upfiles/5237/3BD1D7F1CD6E49B9A9CD5487C4DFD6C4.jpg[/IMG]
Old Feb 22, 2008 | 3:03 PM
tahoe07's Avatar
Go tot he dealer and get the new window. After the warranty is out start repairing out of your own pocket. If your repair goes south the dealer may balk at warranty work.
Old Feb 23, 2008 | 12:04 AM
ncfr2544's Avatar
thanks for the responses...I think I will try the Permatex stuff. Seems easy enough. Probably easier than going to the stealership and having to explain how this wasn't my fault...plus I should have some left over to use when the other side falls off!!! Thanks again
Old Feb 23, 2008 | 12:54 AM
Colorado Chief's Avatar
Just had mine done at the dealer, they re-solderedit back on and it has held so far. If that doesn't work they have to replace the back window..
Old Feb 23, 2008 | 3:28 PM
mikepardy82's Avatar
15 Year Member
the best thing to use is silver solder u can get at electronics store (source) it's a high heat solder do not uselead or tinsolder it will not hold clean the tab and window with 500 grit sandpaper and alcohol. this is what gm recommends.
Old Feb 24, 2008 | 1:45 AM
ncfr2544's Avatar
ok..thanks Mike...do you think this might hold longer than the Permatex stuff? Sounds like I'm not the only one this has happened to.
Old Feb 24, 2008 | 5:22 PM
15 Year Member
yes i usedPermatex kits and u can only use it oncesilver is much better.
