Hard starting 1996 Silverado
Old Nov 21, 2008 | 3:39 PM
logman147's Avatar
Default Hard starting 1996 Silverado
I have a 1996, always maintained very well Chevy Silverado, it has the 5.0 liter engine. The issue is I have been having problems with it hard starting. The temperaturte outside has nothing to do with it. As long as I start it every day its O.K. but it just takes to many cranks for it to turn over. Could it be the fuel pump or possibly a filter being clogged? I spray in a little bit of starter fluid and it starts up. Let the truck sit for a few days and its very hard to start.
Old Nov 21, 2008 | 4:02 PM
Default RE: Hard starting 1996 Silverado
Put a fuel pressure gauge on it to see what its doing. Sounds like it could be the pump
Old Aug 13, 2012 | 10:10 AM
osborneak13's Avatar
does yours have a throttle body,if so my 5.7 liter does the same it is very easy to start first try the any time after that it cranks and cranks before it hits...i put a fuel pressure regulator on it and i can turn on the switch and it builds up pressure then when the pump kicks off it looses it . i have herd from a few people it is the spyder injectors. under the throttle body...
Old Aug 13, 2012 | 10:57 AM
jesse06's Avatar
thats the problem with mine also... When I turn the key on and let it sit for a minute then start it, it usually will start pretty quick
Old Aug 13, 2012 | 11:46 AM
The check valve in your fuel pump assembly is bad. It is letting the fuel bleed back into the tank. I added an inline check valve in my fuel line and solved the problem.
Old Jul 19, 2022 | 5:53 PM
Dpaul's Avatar
Default I'm having sim issues.i saw video on this and thought that sounded real close
hey chiming in here..I feel my truck is doing this also. How do we add an inline check valve? Where do we get it
Gabriel Perez
Jul 2, 2019 9:30 AM
skram
Mar 23, 2019 9:35 AM
Garon
Nov 21, 2011 8:18 PM
brandonvbh
May 4, 2010 9:11 PM
Banshee79
Dec 13, 2008 4:08 PM
