Platform: A-, G-, & W-body
95 lumina coolant loss
Old Feb 11, 2009 | 5:29 AM
redneckfromnb's Avatar
Default 95 lumina coolant loss
i seem to be going through alot of coolant lately,it dont seem to be leaking out the usual places,and it isnt going in the oil.i pulled off the throttle body and there is a small amount of moisture there after idling the car.by the way isnt the thermostat fun to change on a 3.1.hope someone can tell me whats wrong.
Old Feb 11, 2009 | 11:32 AM
izod's Avatar
this is a 3100, correct? have you checked the intake manifold? They are notorious for leaking coolant and GM has an updated gasket available from the dealer. It is a relativly cheap repair if you do it yourself, a fortune if you pay some one.
Old Feb 11, 2009 | 5:57 PM
have fast do you loose coolant? do you have white smoke coming out the tail pipe?
Old Feb 12, 2009 | 4:52 AM
im losing about 1 gallon a week and theres no white smoke after it has been running for a minute or so
Old Feb 12, 2009 | 1:37 PM
A gallon a wek is quite a bit....there should be an obvious leak if you are sure it isn't internal
Check the water pump, and as izod said, the intake. Especially under the throttle body area.
Old Feb 12, 2009 | 1:46 PM
i cant check under the throttle body until i order a new gasket,it is always wet on the thermostat side,but it dont seem to be leaking at the thermostat
Old Apr 8, 2009 | 6:24 AM
HotSauce6226's Avatar
Impala Super Moderator
Check under you radiator cap. I bet its all gunked up
Old Apr 8, 2009 | 7:44 AM
A slight amount of gunk will be there with age...
Old Apr 8, 2009 | 8:05 AM
Oh im not talking about a slight. I bet he has enough to cake his finger
camotruck55
10
Jun 3, 2015 9:12 AM
usassh
Oct 12, 2013 9:36 PM
Pinkypinks
12
Jul 11, 2012 12:15 PM
jdpilot
Feb 9, 2011 3:21 PM
candee1977
Jan 26, 2011 2:22 PM
