2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Relay/switch that shuts the radio off when you open the door
Old Feb 28, 2009 | 9:12 AM
tskilbride's Avatar
Default Relay/switch that shuts the radio off when you open the door
How can I tap into the power wire/fuse that shuts the radio off after you open the door?
I would like to have my police scanner, Garmin GPS, and XM radio shut off when I open the door just like the radio.
TIA,
Tim K.
Old Feb 28, 2009 | 3:07 PM
would help if you gave us the year
Old Feb 28, 2009 | 3:35 PM
tskilbride's Avatar
Yeah, that would help. Its a 2005.
Old Mar 3, 2009 | 2:20 PM
rbarrios's Avatar
im not sure about this..
but I think this is related to the computer...
it gets a signal that door is opened.. and it shuts power off to those accesories.
Old Mar 3, 2009 | 2:47 PM
tskilbride's Avatar
Bummer. . . It drives me crazy to manually turn off/on my sirius radio and it drives me crazy when I turn my car off and the sirius radio turns off while the AM/FM stays on playing static.
Old Mar 3, 2009 | 3:28 PM
It may be BCM controlled. in that case you will have to install a relay that will be activated on the open of the door switch.
Old Mar 3, 2009 | 5:59 PM
In the driver kick panel, there is a harness that goes into the drivers door boot. cut it open and you'l find a yellow wire. It will test as R.A.P.(Retained Accessory Power)
This is the wire you are looking for
Old Mar 3, 2009 | 6:58 PM
tskilbride's Avatar
Thanks!!!
Tim K.
Old Mar 7, 2021 | 12:42 PM
Charles Christen's Avatar
Originally Posted by tskilbride
Thanks!!!
Tim K.
just curious if the yellow wire in the door boot worked for you???
Old Mar 7, 2021 | 12:45 PM
tskilbride's Avatar
I honestly don't remember what I did. That was quite some time ago.
Tim
