2016 Camaro
Platform: F-Body & Zeta.
1979 Camaro Berlinetta manifold question
Old Mar 24, 2009 | 9:12 PM
Djmack's Avatar
Exclamation 1979 Camaro Berlinetta manifold question
I have a manifold from my old 1979 Trans-am its a pontiac performer with carburetor, and i was wondering if it would be able to fit the chevy engine.
its came off a pontiac 403
and im wanting to put it in a chevy 305
Old May 21, 2009 | 1:18 PM
RixZ-28's Avatar
The answer is no....
First of all the 403 (which I also have in my 79 T/A), is an Oldsmobile small block that even Olds doesn't "recognize" as one of their own.
The Olds engine has a wider intake valley....(the heads are farther apart). Chevy blocks are much narrower.
Be careful on selecting an aftermarket manifold for the 305....the ports are much smaller than the 350....good luck!
Old May 22, 2009 | 2:33 PM
Djmack's Avatar
so would a 350 carb work on the 305?
Old May 23, 2009 | 10:18 PM
RixZ-28's Avatar
So what specifically is a "350 Carb"?????
What year is the 305???
Was it originally fuel injected???
If so, the fuel pressure is much too high for a carb.....a pressure regulator will have to be used.
If the carb is a 350 CFM unit....I'm guessing it's a 2 bbl....
Need more info please!
brandiwh
Camaro
Jul 1, 2021 1:48 PM
duckyontheweb
Feb 20, 2014 1:15 AM
cam_79
Site Feedback
Aug 26, 2013 12:25 AM
vzfox
Camaro
May 11, 2007 5:43 PM
