2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Chevy Impala
Old May 28, 2009 | 4:49 PM
vegterrl03's Avatar
Exclamation Chevy Impala
Hi, lately when I've been driving my 2002 chevy impala LS car (IN THE SPRING WITH NOW SNOW) my ABS system will kick in randomly and when I accelerate, the car makes a vibrating noise. This also happens randomly when I brake, the brakes will vibrate like I'm slipping on ice. I am not accelerating fast or braking fast. Do you have any idea what the problem could be and what the cost is in general to fix something like that. (the ABS light is not on. However when I accelerate and keep accelerating through the vibrating noise, the ABS light does come on sometimes. But when I restart the car, it turns off)
Old May 28, 2009 | 11:24 PM
May be a faulty wheel speed sensor. Without a DTC, it would be hard to pinpoint the exact cause. It could be also be a faulty ABS unit. Its hard to tell.
Old May 28, 2009 | 11:29 PM
suzuki-guy's Avatar
Does it make noises when turning? My ABS came on and off randomly when my hub assembly went out!
Old Jun 1, 2009 | 10:35 AM
jondoe28's Avatar
Try cleaning the electrical connection on each front wheel. Mine had a similar problem. If that doesn't work, then go for more expensive fix.
Old Jun 1, 2009 | 6:41 PM
vegterrl03's Avatar
yeah, it started coming on when i would turn my steering wheel but now it also does it just when i accelerate and stop.. how to i clean the electrical connection? Thanks.
Old Jun 2, 2009 | 9:14 AM
jondoe28's Avatar
Behind the front wheels, near the brake calipers there's a snap connector where they plug
together. Clean the metal contacts with sandpaper/steel wool and electrical contact spray cleaner. Sometimes the easiest thing works, if not then go forward with other solutions.
I read somewhere that a lot of good hubs/abs sensors get thrown away because of the
poor connection. The new ones work then becase of unplugging/plugging them in creates a better contact. Let me know if this works or not.
Old Jun 3, 2009 | 5:34 PM
vegterrl03's Avatar
hey thanks for the info!! i'll try it and let you know how it goes.
gearheadtx
Apr 13, 2008 3:35 PM
Ace69
Dec 3, 2005 8:52 PM
