Chevrolet Malibu
Battery getting drained
Old Jun 27, 2009 | 8:42 PM
amolg's Avatar
Unhappy Battery getting drained
Hi,
I have Chevy Malibu 2002 model. The car battery is getting drained overnight. I have shown to mechanic but he could not fix the problem. I had already spent 600$ but the issue is still not fixed. He has replcaed the hood switch as well as ignition switch but still battery is getting discharged.
Old Jun 28, 2009 | 8:16 PM
MDTAHOE's Avatar
You should take it to a better mechanic. One that knows how to properly check for a draw
Old Jun 29, 2009 | 1:40 PM
Don't for get to check some things for yourself, check to make sure the glove box light is not staying on if you have one, unplug any accessories that you may have added, remove any chargers from the cigarette lighter(s).
Take a walk around your vehicle in the evening when its dark and check for any lights on.
Its a little tedious but you can try removing 1 or 2 fuses at a time in the evening, leaving them out over night to help identify the possible circuits that are causing the drain.(putting them back in the morning and if vehicle starts you know what fuses were pulled and what circuits were causing the drain)
just some suggestions that require no deep tech know-how or tools
jecobb
Aug 1, 2021 4:37 PM
luv2ski
Sep 23, 2013 2:55 PM
kllawson
Avalanche
Dec 22, 2010 6:31 AM
rwrows
Apr 6, 2008 12:04 PM
92600sel
Jun 8, 2006 7:51 PM
